LUA Scripts not running Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
DarkAllMan
Post by DarkAllMan » Monday 10 July 2017 14:24
Since a couple of beta updates ago, it seems that script_device_pass2php.lua is no longer called.
I have added to the first line:
print('this will end up in the domoticz log')
to see if its running, but nothing shows in the log.
When I revert to the stable release, they start showing up in the log.... when I update back to latest beta, messages stop showing up again.
Who can tell what's going on? Has anyone got the same issues?
jvandenbroek
Target OS: Raspberry Pi
Re: LUA Scripts not running
Post by jvandenbroek » Monday 10 July 2017 15:34
Most likely related, see note here: https://www.domoticz.com/wiki/Events#By ... ion_folder..
DarkAllMan
Post by DarkAllMan » Monday 10 July 2017 15:38
jvandenbroek wrote:Most likely related, see note here: https://www.domoticz.com/wiki/Events#By ... ion_folder..
Am I correct in understanding that if there is no device called pass2php, it will never be called?
Because now it only calls when that device changes?
Nevermind, when it does not find the device name, it calls the script on any device change...
jvandenbroek
Post by jvandenbroek » Monday 10 July 2017 15:40
Because now it only calles when that device changes?
No the opposite, if that device doesn't exist, it should be called on ALL device updates. Make sure you don't have a hidden devices called 'pass2php' (case insensitive)
DarkAllMan
Post by DarkAllMan » Monday 10 July 2017 15:41
There is no (hidden) device called pass2php, but it seems its never called anymore.......
I will try to rename the script to a certain device and see if it runs on that device status change...
jvandenbroek
Post by jvandenbroek » Monday 10 July 2017 15:44
DarkAllMan wrote: There is no (hidden) device called pass2php, but it seems its never called anymore.......
Well that's not correct then, not sure why this doesn't seem to work for you, works fine here and for others as well since that update. And if you just name it something else? But this name should work just fine...
Edit: which platform are you on? Your forum info says Linux, but is that the case for this installation?
DarkAllMan
Post by DarkAllMan » Monday 10 July 2017 15:49
Tried to rename to a certain device, but it was not triggered on this device status change.
Renamed to a random name, which does not exist, still nothing.
I'm on Ubuntu Server.
jvandenbroek
Post by jvandenbroek » Monday 10 July 2017 15:51
No Lua errors in log just after a device update?
Can you disable dzVents under settings, restart Domoticz and try again? And I assume you're currently on the latest beta (> v3.8073)?
DarkAllMan
Post by DarkAllMan » Monday 10 July 2017 16:18
jvandenbroek wrote:No Lua errors in log just after a device update?
No LUA errors!
I'm on V3.8073, disabling dzEvents does not change behaviour.
jvandenbroek
Post by jvandenbroek » Monday 10 July 2017 16:34
Could you get the source as described here: https://www.domoticz.com/wiki/Installin ... spberry_PI
Before compiling (make -j 3) edit the file main/EventSystem.cpp, add this line 1260 (just above the line "bool bDeviceFileFound = false;):
 _log.Log(LOG_STATUS,"EventSystem: Lua directory is %s", lua_Dir.c_str())
This way we know for sure the correct folder is read. Maybe the compiler falsely optimizes the lua_Dir string away, this way we now if that's the case.
DarkAllMan
Post by DarkAllMan » Monday 10 July 2017 16:45
jvandenbroek wrote:Could you get the source as described here: https://www.domoticz.com/wiki/Installin ... spberry_PI
I will try to continue tonight... although a quick look says, I'm gonna need some extra support...
I think my install was "the easy way"... And I have no clue, what you want me to do....
DarkAllMan
Post by DarkAllMan » Monday 10 July 2017 20:09
ok, can you please explain what you want me to do, without loosing my current config etc? I'm not sure how to proceed....
jvandenbroek
Post by jvandenbroek » Monday 10 July 2017 20:24
If you follow the steps one by one and make sure you use another directory where you execute the "git clone" line, you should not worry about losing anything. All settings are in domoticz.db, so you could copy that one over to the new Domoticz directory after compiling.
I can help you if you could provide me ssh access (normal user should be fine, no root needed), just make sure to first install the packages with apt as described. If you don't mind me logging in, send me a DM with details.
Verstuurd vanaf mijn SM-N930F met Tapatalk
DarkAllMan
Post by DarkAllMan » Monday 10 July 2017 21:55
It seems the LUA is now triggered when running from shell ./domoticz
But when running from system start, its not: systemctl start domoticz
Very strange!
jvdz
Domoticz version: Stable
Post by jvdz » Tuesday 11 July 2017 9:26
Something with security rights to the files maybe?
Jos
DarkAllMan
Post by DarkAllMan » Tuesday 11 July 2017 16:17
Permissions seem to be ok...
But I confirmed that LUA is running when calling domoticz from shell and not from systemd (systemctl)
mivo
Post by mivo » Tuesday 11 July 2017 16:40
please review or post here startup script of domoticz (usually /etc/init.d/domoticz.sh).
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
DarkAllMan
Post by DarkAllMan » Tuesday 11 July 2017 16:50
mivo wrote:Hi,
/etc/systemd/system/domoticz.service
[Unit]
       Description=domoticz_service
       After=network.target
[Service]
       User=username
       Group=username
       ExecStart=/home/username/domoticz/domoticz -www 8080
       #WorkingDirectory=/home/domoticz
       #give the right to open priviliged ports
       #ExecStartPre=setcap 'cap_net_bind_service=+ep' /home/username/domoticz/domoticz
       Restart=on-failure
       RestartSec=1m
       KillMode=process
       #StandardOutput=null
[Install]
       WantedBy=multi-user.target
mivo
Post by mivo » Tuesday 11 July 2017 17:13
Just for sure - do you try to start Domoticz from shell by user id specified in Systemd unit file ?
# su - randall
$ /home/username/domoticz/domoticz -www 8080
My toys:
DarkAllMan
Post by DarkAllMan » Tuesday 11 July 2017 20:36
mivo wrote:Just for sure - do you try to start Domoticz from shell by user id specified in Systemd unit file ?
# su - username
I login with the specified username that's in the code above.
I just go to ~/domoticz and run: ./domoticz
Then LUA is working.
When starting with systemctl start domoticz, LUA is not working.
Users browsing this forum: No registered users and 4 guests
