New (beta) version library requirement (Arm/Debian)
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
gizmocuz
Target OS: Raspberry Pi
Post by gizmocuz » Saturday 09 September 2017 12:28
For new (beta) versions it is required that libssl 1.0.0 is installed.
This might not be at your current system (for example a raspberry running rasbian jessy or older)
To install this, issue:
sudo apt-get install libssl1.0.0
After this you should be able to upgrade to the new beta via the web interface, or via the command line
cd domoticz
./updatebeta
for people running an armv6 system (raspberry pi 2 or below) you might need to issue
wget http://mirrordirector.raspbian.org/raspbian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
Docdigit
Domoticz version: 3.8153
Re: New (beta) version library requirement (Arm/Debian)
Post by Docdigit » Saturday 09 September 2017 12:42
thanks, that works like a charm!
With both feet on the ground to can't make any step forward...
blacksn0w
Post by blacksn0w » Saturday 09 September 2017 13:02
Working like a charm on Stretch with libssl1.0.2.
Thanks for your effort!
Migration in progress, hello Home Assistant.
JuanUil
Domoticz version: 2.xx
Post by JuanUil » Saturday 09 September 2017 13:14
Hi Gizmocuz,
I followed your struggle to get this fixed CHAPEAU!!!
but....
when I give the sudo apt install libssl1.0.0 command I get: sudo: apt: command not found
What am I doing wrong?
Again many thanks for all your effort!
Jan
blacksn0w
Post by blacksn0w » Saturday 09 September 2017 13:20
Hi Gizmocuz,
but....
Jan
Use sudo apt-get install libssl1.0.0
JuanUil
Post by JuanUil » Saturday 09 September 2017 13:35
thnx blacksnow.
It returns that the library is already installed.
But when I upgrade to the latest beta domoticz won't start anymore, I get:
sudo service domoticz.sh start
/home/pi/domoticz/domoticz: error while loading shared libraries: libudev.so.1: cannot open shared object file: No such file or directory
Jan
Phantom
Domoticz version: 3.8922
Post by Phantom » Saturday 09 September 2017 15:45
Thanks that worked here also again
pi@raspberrypi:~ $ sudo lsb_release -d
Description:    Raspbian GNU/Linux testing (buster)
, sadly had to go back to the latest stable version because i have a couple of python plugins also.
Any idea if/when that will be activated again? (https://github.com/domoticz/domoticz/co ... 317c67804f)
pvangorp
Domoticz version: Latest B
Post by pvangorp » Saturday 09 September 2017 17:39
pi@raspberrypi:~/domoticz $ sudo apt install libssl1.0.0
Reading package lists... Done
Building dependency tree
Reading state information... Done
libssl1.0.0 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
./updatebeta
Still doesn't work.
pi@raspberrypi:~/domoticz $ sudo service domoticz.sh status
● domoticz.service - LSB: Home Automation System
   Loaded: loaded (/etc/init.d/domoticz.sh)
   Active: active (exited) since Sat 2017-09-09 17:39:05 CEST; 6s ago
  Process: 1928 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUCCESS)
  Process: 1937 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
Sep 09 17:39:05 raspberrypi domoticz.sh[1937]: Illegal instruction
Sep 09 17:39:05 raspberrypi systemd[1]: Started LSB: Home Automation System.
I had not problems with 8389
Krosik
Post by Krosik » Saturday 09 September 2017 18:37
For raspbian users.
Add the following two lines into /etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb http://archive.raspbian.org/raspbian jessie main contrib non-free rpi
apt-get update
apt-get -t jessie install openssl libssl1.0.0 openssh-client openssh-server ssh
frank3523
Post by frank3523 » Saturday 09 September 2017 18:59
I also have the same problem after updating to latest domoticz version
pvangorp
Post by pvangorp » Saturday 09 September 2017 19:05
I took a clean Pi and did a new install, with no devices and stable was ok, but when I did an update to the latest beta. Same as on my test environment.
pvangorp
Post by pvangorp » Saturday 09 September 2017 19:13
For raspbian users.
apt-get update
Doesn't make a difference in my case. The system says already the newest version on all.
I even did a
sudo apt-get --reinstall install openssl libssl1.0.0 openssh-client openssh-server ssh
Still doesn't work on a Pi Zero W
pvangorp
Post by pvangorp » Saturday 09 September 2017 19:27
I've done some testing on several Raspberry Pi's in combination with v3.8390
1. My test Pi Zero W -> Illegal instruction
2. A clean new installed Pi Zero W -> Illegal instruction
3. My production Pi 3 -> No issues
4. A clean Pi3 -> No issues
So I'm almost certain this is a Pi Zero W thing. CPU issue???
frank3523
Post by frank3523 » Saturday 09 September 2017 20:03
I'm using a Pi2.
I also did all the updates as told but with no luck.
pvangorp
Post by pvangorp » Saturday 09 September 2017 20:04
I'm using a Pi2.
Looks like a hardware compatibility issue. BCM issues as with GPIO before???
frank3523
Post by frank3523 » Saturday 09 September 2017 20:15
reverted back to latest stable all is working fine now.
pvangorp
Post by pvangorp » Saturday 09 September 2017 20:25
I looked on the internet and there are several cases that explain applications that crashes with "Illegal instruction" on ARM6 (e.g. Pi Zero W) and work fine on an ARM7 (e.g. Pi 3).
PI 3
# egrep -i 'model|hardware' /proc/cpuinfo
model name      : ARMv7 Processor rev 4 (v7l)
Hardware        : BCM2835
Pi Zero W
model name      : ARMv6-compatible processor rev 7 (v6l)
Hardware        : BCM2835
Apparently the libssl1.0.0 from Raspbian Jessie has been compiled for armv7 and can't work on armv6 Pi.
emme
Domoticz version: latest
Post by emme » Monday 11 September 2017 8:32
Thank you guys!
I did a great work!
That's one small step for a programmer, one giant leap for me!
Raspberry Pi3 + AeonStick G5 + RFXCOMM433 + iRTrans Server + NodeJS
There's no stress in the mess!!
vthinsel
Post by vthinsel » Monday 11 September 2017 10:07
Since the last beta update I'm also facing issues with libssl.
Went through the describded steps (also tried some libssl versions from https://packages.debian.org/fr/jessie/libssl1.0.0
Re-enabling static linking would probably help people having issues like me, but I guess there are good reasons to have it removed.
I'm using domoticz on an old raspberry 1, model B.
pi@domotique:~/domoticz $ cat /proc/cpuinfo
processor       : 0
BogoMIPS        : 697.95
Features        : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xb76
CPU revision    : 7
Hardware        : BCM2835
Revision        : 000e
Serial          : 000000008f691da8
I'll try to get another libssl for that hardware
gizmocuz
Post by gizmocuz » Monday 11 September 2017 16:48
We can not static link openssl as this will break the curl library, which should also be statically linked then, and this i could not get to work.
If you can get this to work, that would be great! If both are not statically linked, HTTPS will not work
